WRF767SDHZ04 whirlpool refrigerator leaking
Brand:Whirlpool
**Model Number:**WRF767SDHZ04
Main Symptom:leaking from where ice maker is located and from dispenser housing
What happens & when: leaking
Whirlpool Refrigerator leaking from where the ice maker is and the water dispenser housing
Does it seem like the ice maker is overfilling and the water dispenser is randomly shooting out water or that their both just steadily leaking?
All I know is when it calls for water that is what’s happening. It’s not a fast pressure leak just a slow stream. Also have stated ice maker and both water valves have been replaced. What do you suggest replacing or doing now ?
With what has been replaced, if it seems like it is only happening when calling for water then I’d suspect that the diode pack built into the unit wiring harness W11614808 in the compressor area is bad. You’ve gotta replace that harness to replace the diode pack but it isn’t too bad to do, just just disconnect the old harness and connect the new one in its place.
