Wont start
wont start have power everywhere except at timer help
Unplug and pull out lay on its front.. remove large rear panel next to where the vent hose attached is the blower husing .. ckeck the thermal fuse by removing 1 wire and check for continuity… if none replace it and clean vent from wall to outside..here is a pic of the fuse
