Won't start washing cycle
Started a load. Filled as usual, than didn’t do anything. After thinking it was a drain problem, we
emptied all water, took all pieces out of center to check drain. Lots of soap buildup and a piece of melted plastic, never did figure that one out, may have been here when we moved in. Cleaned up all pieces and resembled, started and tub filled but would not switch to washing mode. Any thoughts??
Having the same exact issue?
Kenmore: Model# 665.13003N511
