Won't spin or aggitate
I have a frigidaire front loader washer that wont spin or aggitate. I t will fill with water and drain. I have installed a new motor and door switch with no improvement.
Hi.
Do the following tests to determine it it’s bad timer or the motor controller.
You can always return any unused parts even if they been installed.
Here are the breakdown diagrams and Replacement parts for Frigidaire GLTR1670AS0 Frtld Wshr - Frigidaire Gallery | AppliancePartsPros.com
Thank you.
Simon.
Front load washer with AC motor - drive motor does not turn.pdf (183.4 KB)
