Won't fill
my dishwasher won’t fill
First check to nake sure there are no restrictions in the water supply. You can do this by turning it off at the cut off valve under the sink. Then disconnect the water line from under the dishwasher. Next, using something to catch the water flow, turn the cut off valve back on. Report your finding.
