Won't drain
dishwasher don’t drain during a cycle… but when you cancel and restart, it will drain. bad board?
I would see if there is a tech sheet behind the toe plate at the bottom of the dishwasher. The tech sheet will tell you how to run the diagnostic cycle for testing. Of hand I would have to say it does sound like it could be a problem with the control board, AP3961536
