Won't complete a washcycle
The dishwasher will fill properly, go through the mechanical stage of washing, drying etc. and then drain properly. Problem is during the wash cycle no water reaches spray arms. If you open the unit immediately after the unit shuts off all the dishes are bone dry. I did replace the water valve next to the float switch.
Deperate Dave
wifes not happy
I cannot find any info on the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
Tried here and the Frigidaire sirte.
Is the a USA model, if not I may not be able to find any info.
Did you check that the float switch was closed (0 ohms)?
