Dryer gets hot but not tumbling ?
Part Details - WHIRLPOOL Motor switch, dryer, part number: AP2975202
More info on the problem would be useful.
Sounds like your belt is broken.
The motor has a centrifugal switch on it. This switch closes when the motor gets close to operating speed. Since you have heat the motor must be running.
Could be that there is a switch problem but more likely the above.
[QUOTE=denman;196509]Here are your parts
Could be that there is a switch problem but more likely the above.[/QUOTE]
I will take it apart this morning just in case how do u test the motor switch and or the motor itself?
