ordered coils…23 bucks with shipping:cool: not bad…plugged in…seen glow so ing. is good…
didnt see a flame sensor on this model http://www.whirlpool.com/catalog/product.jsp?parentCategoryId=113&categoryId=119&subCategoryId=120&productId=1533&view=1#tabs
…so ordered only coils.
dryer was heating a little,went low hot then turned cool…now nothing,no heat.:rolleyes:
hope this is problem…cause im not in mood to spend 500-$600 for new one.:eek:
anyone change these COILS after having no heat…
txs all…
WOW…there here already.ordered yesterday !!! the coils. anyway…installed them…and heat was on…
youll have to take entire face of dryer off…theres no access door on my unit. vacumed all the dust out off motor,burner,vents…this thing should dry like new…airflow will be much better.
[quote=aircargoo;245708]ordered coils…23 bucks with shipping:cool: not bad…plugged in…seen glow so ing. is good…
txs all…[/quote]
Your flame sensor,also known as a radiant sensor, is located on the burner inlet tube housing(a little black box with 2 wires attached to it, usually black and white)on the outside of the inlet tube.
Are you sure your connections at the new coils are not loose ?
Are you sure you did not loosen any of the other wire connections by accident ?
Are you sure you did not crack or break the igniter ?
After the repair and at this time nothing occurs, no clicks, no glow from the igniter and of course no flame, is that correct ?
Power to the igniter and radiant sensor is dispersed from the coil harness to the components, and power to the coils is dispersed from the timer,through the thermostats and or the temperature select switch(on some models) in a heating cycle. Make sure the dial is in a heat mode, not a cool down or no heat setting.
