Wiring terminal block
Hello
I am replacing the terminal block on the dryer and need help on which wire goes on the terminal block. I have a red wire coming from the bottom and 2 black wires coming from the top and 2 white wires. The diagram on the back shows the center of the 3 stud block as the ground. Where do I connect the wires on the block?
Here is the install sheet from Maytag
http://www.kitchenaid.ca/assets/pdfs/literature/PYE1000AYWII.pdf
The important part is to check that the center connector Neutral/ground is connected to the frame of the unit. This is for a 3 wire hookup.
A 4 wire hookup uses a different ground and Neutral hook up, see the install sheet.
