Wiring on thermostat wp2198202
Brand:kenmore
Model Number:105.50562990
Main Symptom:
What happens & when:purchased a thermostat #wp2198202 terminal spades are at different locations . Which terminal does red wire go on bent or straight.
Original thermostat spades are top and bottom. New thermostat spades are side by side
As the thermostat is just a two-terminal open/close switch, the red wire can go on either of the two brass terminals and it will not make a difference.
