I have a Jenn-Air Model JED8430ADB drop in cook top with bad dual element switch.
Old switch is 209050/7403P406-60. I have replacement switch 12002125.
I am having trouble getting the correct wiring plan done as the switches are not labeled the same.
I have also attached the wiring scheme from the cooktop paperwork, as well as the instructions that were included in the new switch.
I have identified wires with daisy chains, and with piggy backs. The connections I have are a little different in that the crimp pin simply holds an uncut section of the wire, with the insulation cord on each side. I will call those “double” wires until the experts tell me what name they should be called.
Old Switch
Terminal 1 single (orange) wire to knob control.
Terminal 2 double (black). Half goes to RWB power, other end goes to the piggy backed L1 on sister switch.
Terminal 3 single white corded wire to dual heating element
Terminal 4 (single red) corded wire to dual heating element limiter.
Terminal 5 (double red) half goes to RWB power, other side goes to sister switch.
Terminal 6 (single yellow) wire to heating element left side of terminal,
Based on other posts, this is how I have completed the wiring. Besides the fact that the new switch doesn’t neither the large nor the small coils on this (new) element warm up. The on indicator does glow amber. The on indicator under the switch does glow amber. All other elements are functioning.
This is my new wiring scheme.
Jumper from P1 to S1
Old Terminal 1 single now to S2
Old Terminal 2 (dual black) now to P1, next to jumper
Old Terminal 3 now to 4
Old Terminal 5 (double red) to P2
Old Terminal 6 now to 4a
We turn on the breaker and the dual element will not warm up.
Help, help, help oh yee Appliance Repair Gods! ![]()
Wiring scheme for 8104P688-60.pdf (1.9 MB)
Wiring instructions for new switch..pdf (1.8 MB)
