Wiring diagram
Dryer didn’t heat so I replaced the heating coil and thermostat. In the process, I removed the back from the top control panel. When I lifted the dryer top, it fell backward and some of the wiring connectors came loose on the timing control knob located on the left rear of the dryer. It is a series 10 and I cannot decipher the wiring schematic to determine where the loose wires belong. Can you help
Here are your parts includes a wiring diagram.
Parts for Admiral LNC7764A71 Dryer - AppliancePartsPros.com
The diagram is the bets I can find but does not show all wire colors and it also looks like some colors are used for more than one device/part so you may have to trace the wires to be sure you get the timer hooked up OK.
