This may be a stretch due to the age of the machine, but I am hoping to find a wiring diagram for the timer for this gas dryer. When I pulled it out I noted that the tabs were labeled and that the wires were labeled as well. What I failed to note was that the power wires to the drive motor were not labeled and the wires to the buzzer were not labeled either. Now I need to determine which tabs they are connected to. Thanks in advance for your help.
See if this site helps. Use the first six characters as your model number, as your full model number does not come up.
http://www.frigidaire.com/manuals.aspx
Good luck, and let us know if this works
Yep, that’s it, and in the immortal words of Elvis P. Handyman, “Thank you, thank you very much”.
Great, glad that worked out for you!
