Brand:Ge
Model Number:JRS04BOW3BB
Main Symptom:Wire connector fell off
What happens & when:Heating element quit working 3 days ago
Hi, good morning! Are you needing the bake element itself, or are you looking for the wire harness that connects to the bake element? GE WB44K5013 Oven Bake Element | Genuine OEM Part
The wire harness. One of the connectors broke off and can’t be found. I believe the bake element is good. It’s just not getting any power.
muscadineman45:
JRS04BOW3BB
Hi, you can pick up a replacement spade connector at Lowe’s or Home Depot and simply crimp it back onto the wire. Just make sure you get the correct size connector for the wire and terminal.
We tried and what they have are different size from the original.
ok you would need to get the whole harness i can try to find that for you.
