I was not careful in attempting to remove the unit from the window and it fell. Fortunately it was cushioned by a bush. In the fall, the thermostat knob brokd and the wire from the plug came loose. I was able to piece it back together without knob control function and it appeared to work fine. I am not sure what level the thermostat is set at an cannot control the setting due to the damage. I have two questions:
a ground wire also came loose and I am not sure what it is to be connected to. Does the thermostat require a ground?
[quote=Jcrane;416906]I was not careful in attempting to remove the unit from the window and it fell. Fortunately it was cushioned by a bush. In the fall, the thermostat knob brokd and the wire from the plug came loose. I was able to piece it back together without knob control function and it appeared to work fine. I am not sure what level the thermostat is set at an cannot control the setting due to the damage. I have two questions:
can I get a replacement part?[/quote]
Yes to both questions just supply model number.
