My Window A/c Is Blowing Twice As Fast Through One Louver While Barely Blowing Anything Through The Other Louver. This Is Causing The Unit To Work Twice As Hard Any Ideas What’s Wrong?
Srbishoplx
[QUOTE=srbishoplx;852]My Window A/c Is Blowing Twice As Fast Through One Louver While Barely Blowing Anything Through The Other Louver. This Is Causing The Unit To Work Twice As Hard Any Ideas What’s Wrong?
Srbishoplx[/QUOTE]
Your loover is stuck closed or the lever is malfuncting. You will need to remove the front cover and look at it to see what it is. Many times you can move it from the inside to balance the air flow. Careful as many parts are plastic
