will not start
can only get the washer to run on spin cycle seems like it is the timer any thought the timer is over a hundred dollars i would like to get right the first
Does it fill with water?
Can you be more specific on the problem?
yes it will fill with water the timer never advanced to start the wash cycle could only get it to go into the spin cycle and it emptyed the tub thanks for the reply Gene
My wife just told me that she tried restarting the load. She said the machine acted like it started for less than a second and then shut off. She could here the timer clicking but nothing happened. She tried advancing the timing cycle again nothing happened. She waited for the clicking of the time to continue and then the spin cycle finally started and drained the water and starting spinning. She also tried the other three wash cycles and none of them work either. The only thing that works in all three wash cycles is the spinning cycle that drains the water.
