[COLOR=“DarkRed”]Does the touch pad wear out?[/COLOR]
Yes but usually the unit wears out before the switches.
But like anything else some do just fail.
[COLOR=“DarkRed”]How can I test it to see if buttons are working?[/COLOR]
Yes see the tech sheet for the procedure.
You will need a meter.
The normal way to troubleshoot is to check the control pane (keypad), if it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better. 16026393.pdf (892.6 KB)
