Will not spin with clothes in it, will spin empty
Washer will not continue spin cycle with clothes in it. I get the “unblanced load” error on screen. I replaced the shock. Still with the same problem. I removed the clutch and pulley, cleaned and lubed it. Still the same problem… HELP!!!
Perform the troubleshooting as described in the attached tech sheet.
Here are the breakdown diagrams and Replacement parts for MAYTAG FAV9800AWW Washer - Top Loading | AppliancePartsPros.com
Neptune TL - top load FAV9800 - FAV7500 Tech sheet.pdf (987.6 KB)
[COLOR=#000000][FONT=Arial][SIZE=3]I own one and refurbished a few for other owners. I have a couple questions and I will see if we can drill down to a fix.[/SIZE][/FONT][/COLOR]
[FONT=Arial][SIZE=3][COLOR=#000000]Did you follow this post? [/COLOR][COLOR=#333333][COLOR=#507aa5]Maytag Neptune load unbalance[/COLOR] [/COLOR][COLOR=#333333]and try the test in the post beginning with my statement “”[/COLOR][COLOR=black]One last step before you clean up those pesky Clutch Pulley One-Way Roller Clutches/bearing.”” ?[/COLOR][/SIZE][/FONT]
[COLOR=#000000][FONT=Arial][SIZE=3]Is the wash tub banging around in Spin Cycle then failing with error code UC or dC unbalance error codes? If so the TDS is signaling to the Control Board properly. [/SIZE][/FONT][/COLOR]
[COLOR=#000000][FONT=Arial][SIZE=3]If you are not taking excessive tub swings in Spin Cycle have you checked the range of motion of the TDS in Service Mode with the test on page 27 of the Service Manual?[/SIZE][/FONT][/COLOR]
[COLOR=#000000][FONT=Arial][SIZE=4][SIZE=3]Did your Clutch Pulley use the Upper Bearing ring? What are the first two digits of your washer Serial Number? The number range is 10 for Series 10 thru 17 for Series 17……….[/SIZE]Dick[/SIZE][/FONT][/COLOR]
Yes I did follow the direction in your previous post. Thanks for that. The series of my machine is 10. I do not experience the tub banging at all at the begining of the spin cycle. It tires to start spinning for a quick 3 seconds and then stops. It repeats this for 5 - 10 mins and then displays the unbalanced load error. The spring inside the clutch/pulley did seem to be bent but not broken.
embrayjg
[quote=embrayjg;287656]Yes I did follow the direction in your previous post. Thanks for that. The series of my machine is 10. I do not experience the tub banging at all at the begining of the spin cycle. It tires to start spinning for a quick 3 seconds and then stops. It repeats this for 5 - 10 mins and then displays the unbalanced load error. The spring inside the clutch/pulley did seem to be bent but not broken.
embrayjg[/quote]
If you release the Washer Top from the base and start a Spin Only Cycle and view the wash basket.
Does the Wash Basket spin CCW with only slight Tumbler rotation before the wash basket begins to rotate CCW?
The Tumblers shoud not rotate once the large wrap SS spring comes under tension.
""The spring inside the clutch/pulley did seem to be bent but not broken. “” Was the Large Wrap SS spring secured by the Pin in the Clutch Pulley and the Pin in the White One-Way Roller Clutch bearing plate mounted on the Clutch Pulley?
Did you clen up the Upper One-Way Roller Clutch bearing also and it and both it and the Clutch Pully mounted One-Way Roller clutch bearings Lock Up solid in the Spin direction as I described in the previous link above.
What are of the thru the lid test of the TDS range of montion checks?
I think I gave you page number from the FAV6800A/FAV9800A SM. The link Gene gave for the SM.pdf has it not sure what the page number is. Let’s make sure the TDS is working as designed.
Got to leave for work will check back in tomorrow…good luck…Dick
do you have the tech sheet for the FAV6800? the 9800 doesn’t help and a previous link to the 6800 doesn’t work any more.
[quote=Gene;287299]Perform the troubleshooting as described in the attached tech sheet.
Gene.[/quote]
Sorry, I don’t. It’s not published on line.
[SIZE=3][COLOR=#000000][FONT=Calibri]It’s a large PDF, 14 Meg file. I have my e-mail on the v-card drop me a line and maybe I can help…[/FONT][/COLOR][/SIZE]…Dick
Thank you all for your help. I ordered a new clutch and pulley and I fixed it. Couldn’t have done it with out you guys.
You are welcome.
If the One-Way Roller Clutch bearing in the Clutch Pulley and the Upper bearing ring can be cleaned up keep them as a spare. Were the parts severely rusted up?
I would reinspect in a few months you may be looking at a Tub Seal replacement down the road. Takes a little bit longer to do and I feel the average DIY’er can accomplish with a little coaching. I have lots of pics from a Series 10 Tub Seal and Outer Tub bearing replacement I did several months ago.
If you don’t DIY I would part the machine out. A Tube Seal, Tranny O-ring and Outer Tub Bearings if you decide to replace at that time are low cost but labor cost would not make it worth it…Dick
Please check your Yahoo email account. Thx Dave
DB. App
Got your questions and answered… join in the thread
[LEFT][COLOR=#000000]FAV6800A/FAV9800A Outer Tub bearing replacement ( 1 2 3 … Last Page) [/COLOR][COLOR=#000000]if you have other questions or concerns…Dick[/COLOR][/LEFT]
[quote=dh1200s;616959]DB. App
[/quote]
Thank you for your support. I will update my progress.
