Will not spin during spin cycle
I have an Admiral washer that will not spin…
When I set it to normal wash and it reaches the spin cycle, it does not spin. There is no loud noise… The timer is still ticking… All cycles work fine… it agitates, drains, fills, etc… just doesn’t spin…
I can set it to other spin cycles on the dial and they work just fine
(spin cycle for permanent press, extra rinse, delicate)
Any help would be appreciated…
Most likely the problem with your washer is a bad timer.
The model number you posted does not come up and I’m not able to give you the right part number for the new timer.
Please, verify the model number or find the part number from the old timer and post it.
The model number is correct…
Will have to pull apart the washing machine tonight to get the number off the timer.
had admiral washer that had similar problem. had leak in hose from tub to pump. leaking water on floor & not draining. when it would finally drain, would not spin. service guy said had leak in hose from tub to pump. when water leaked onto floor also leaked onto hose. the hose would slip & not work properly. when hose replaced (10.00) worked fine in draining tub & spinning. check that out…
