Will not heat water
Model rud4000mqo can not get hot water or heat to dry dishes, heating element is good , is there a fuse that protects the blower and element.
Bill
Could not find any info using the listed Model Number.
Are you sure it is not a RUD
Here is the link to RUD4000MQ0
Model RUD4000MQ0
Take a look at Fuse Item 26 in the “Pump and spray arm parts” section.
