We have water left in the tub at the end of a cycle, I’ve pulled the drain hose from the sink and watched the water run into a bucket, but it just doesnt empty all the way…
I pulled the sump apart and cleaned it out, man was it yucky in there… but still the same result… Any ideas? It’s almost like the pump just isn’t running long enough? is there something else I should clean?
