Will not drain completely
washer will not drain fully during regular cycle… However when I turn the dial to the drain cycle, it will drain the last bit of water with no problem…Any suggestions???
Most likely there is a clog somewhere in the drain line, causing slow drain. The model number you posted is incomplete or incorrect.
