Will not cool or freeze unless forced with code 12
Brand:GE
Model Number:GSH25JGDB WW
Main Symptom: not cooling freezer side or fridge
What happens & when: Display temp is set to 0 and 37, display actual reads -9 and 37 when they are actually both at room temp 77. A forced start with code 12 and everything runs and starts cooling but that is only temporary. A couple hours at best.
Parts or tests already done: ohm readings for thermistors from J1 back board , 4.5k at 77 degrees but only about 8k with ice water .
Johnny01, when the freezer, evaporator, and refrigerator thermistors were placed in the ice water, was the resistance reading taken as soon as the thermistor was in the water or was it allowed to sit in the water for a little bit? Letting the thermistor sit for a minute or so will allow the thermistor to get an accurate reading. However, the main control should have still called for cold air, indicating the main control is not functioning properly. WR55X11072C Refrigerator Main Control Board | Genuine Ge OEM In Stock
