Whrillpool Washer
When washer stops after its washing cycle, it makes a big jolt with loud noice as if some one hit it with a big hammer.
Please read Model # as - LSQ8000HQ0
Double check your model number off the machine, it should be under the hinge area of the lid.
I found the the model # as LSQ8000HQ0
Sounds like the brake is grabbing to hard. You might want to either check it yourself or have a tech look at it.
