how do i replace the belt on my washer white westinghouse WWX433RBW2 model ?
You have to remove the front panel in order to access the belt. Unscrew two screws on the bottom of the front panel and slide it down.
- The belt AP3867042
the problem I am having is not with removal of panel but it is with the actual belt installation on pulleys, i dont know how the tensioner comes into play with belt install .
[quote=Gene;207735]You have to remove the front panel in order to access the belt. Unscrew two screws on the bottom of the front panel and slide it down.
Gene.[/quote]
Hopefully the attached picture will help.
Top load washer belt.pdf (27.1 KB)
Thanks A Million, They Say A Picture Is Worth A Thousand Words It Help And The Washer Is Working Fine
Kelvin
Kelvin,
I’m glad you were able to do it.
I have an older White-Westinghouse washer - Model# LA640JXW3. The washer is not spinning or agitating. I have identified the problem. The pulley wheel is broken and the belt is worn. I went out and purchase a new pulley wheel and belt, but I am having a hard time with the installation of the belt on the pulley. I just cannot get it on there. I tried to put the warn belt back on. I will work for a few moments and fall off. Can anyone give me an idea of what I am doing incorrectly?
Try to push in the idler pulley while installing the new belt.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE LA640JXW3 Wwh(v2) / Top Loading Automatic Agitator Washer | AppliancePartsPros.com
I need to replace washer belt on WHite Westinghouse model LA800M
Gene.[/quote]
Would the replacement work and belt be the same for a model MWX413REW1? My belt is screaming on spin cycle now as well. Many thanks Gene!
I think it should be a Drive V-Belt, part# PS1146950.
