My fridge is on the fritz!! The compressor does not kick in on its own. It will make a clicking noise at the compressor like it is trying. If I peck on the compressor run compacitor it will kick in. Do you think it is the run compacitor or could it be the starter? Any help would be greatly helpful. Thanks alot.
Remove the compressor side cover and check for burnt compressor pins, or a burnt wire.
