My side by side fridge has a door water dispenser. The water comes out clear but now also has particles of white films in it. It looks like some sort of film must be coating the water tubes and is flaking off into the water. I changed the water filter and this did not help, so the film must be in the fridge lines. Did anyone ever hear of this and is there a way to clean flush out the lines to get rid of the stuff? Can the lines themselves be replaced?
Thanks,
Dave
[FONT=Verdana,Arial,Helvetica][SIZE=-1]I am getting white particles from my fridge’s water dispenser. Is it from the water filter?[/SIZE][/FONT]
I have heard a number of complaints recently that the chemicals (specificaly chloramine - a mixture of chlorine and ammonia) used in some water treatment facilities are causing the material the molded plastic refrigerator water reservoirs are made from to break down resulting in white or whitish particles appearing as flakes, flecks or specs in the dispensed chilled water. In that case the water filter is not usually the cause, instead replacing of the chilled water reservoir itself may be necessary.
Most manufacturers originally used a molded plastic water reservoir which is what seems to be effected and breaking down. Many fridge manufacturers are now selling a coil of plastic tubing (like that used in the rest of the refrigerator’s water system) in place of a molded plastic reservoir. You can see a comparison of the two in the following illustration and see some of the replacement kits that are available at the links below.
Even those makes/models that still have the original molded plastic type reservoirs being supplied as a replacement may be able to be updated using one of the ‘tubing kits’ along with the attachment fittings usually supplied with them.
[/SIZE][/FONT]
