Whirpool refrigerator / freezer not cooling
Just the other day, we noticed that the fridge / freezer is not cooling. It happened all of a sudden. At first we tried to turn up the cooling, but not change. I unplugged the fridge, cleaned it out, removed the lower back panel, etc. The fan is working in the bottom, but the compressor is very hot to the touch. I’ve got an old college small fridge, and I remember every time the compressor starts you can hear it, and sometimes feel it shake. I don’t feel anything on the whirlpool. I left it unplugged overnight to cool down - then plugged it in this morning and had my hand on the compressor - I could feel something, but it wasn’t cooling - I’m wondering if it has enough juice to start - maybe a capacitor or something. Any thoughts.
Matt,
Did you hear a loud click, from the compresor when you plugged it in ?
After a few minutes did you hear a slight hum, and if you touched the compressor was there a slight vibration, and was the compressor getting warm ?
Did you notice if there was frost or snow on the back wall of the freezer compartment ?
As far as "juice"to the unit, did you notice if the room light dims , when the unit is plugged in ?
As you can tell there are several "systems"involved in the cooling cycle of the refrigerator, defrost timer, cold control, defrost heater, and a few more.
Another quick check, while the unit is plugged into the outlet,
Carefully, unplug the power cord(while the unit is running) count to 10 and plug the power cord back in. if the compressor is operating properly, you will hear a loud click from the “overload” on the compressor and it will shut down.
Try these quick checks, and let us know what you find,
We’ll have a better idea of what direction to take.
Thanks,
Joe- the lights in the room didn’t change (they are florescent) when plugged in. I thought there was a slight hum to the compressor - I couldn’t hear it - but I felt it. The fan was on once I plugged it in. No loud clunk though - this is what I remember from my old college fridge though. No snow on the back of the freezer. I did the 10 sec test, no loud clunk.
Thanks for your help.
[quote=Joe / APP Team;313223]
Matt,
Thanks,
:slight_smile: :slight_smile: :)[/quote]
[quote=mattj98;313226]Joe- the lights in the room didn’t change (they are florescent) when plugged in. I thought there was a slight hum to the compressor - I couldn’t hear it - but I felt it. The fan was on once I plugged it in. No loud clunk though - this is what I remember from my old college fridge though. No snow on the back of the freezer. I did the 10 sec test, no loud clunk.
Thanks for your help.[/quote]
Matt,
Can you get your hands on a multi meter
AP5641753
So we can test, circuits and voltages at the other comonents that cause the fridge to cool(cold control,defrost timer,compressor etc.) ?
It’ll make things easier and save money in the long run.
Thanks,
My Refrigerator And Freezer Stopped Working. I Cleaned The Dust That Had Collected At The Back And The Underneath In The Front. The Fan Near The Compressor Was Checked And Was Rolling Free. It Was Also Cleaned. Restarted It And It Started Working Again. However, It Would Work For A Fcouple Of Hours And Stop Again. When I Restarted It , It Would Work Again And Stop After A Few Hours. Now It Is Not Working Even When I Try To Restart It** Parts for Whirlpool ED5VHEXVB03**
Was advised to tap on the control knob. I did and it started working again. What’s wrong?
