Whirpool Dishwasher
I own a Whirlpool Dishwasher Model DU920PFGB4. The only wash cycle that works is the HEAVY. The rinse and the remaining buttons do not work. Sometimes when it is running on the heavy cycle, it appears the washer clicks on and off slightly, however it continues to run ON THE HEAVY CYCLE… PLEASE HELP. My wife is expecting to be washing dishes soon…
Replacement parts for WHIRLPOOL DU920PFGB4 | AppliancePartsPros.com
Here are a couple manuals and a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208051291.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/d387c10d7170b7b9852571e0006e9b3e/$FILE/4322451L.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
Often this type of fault is the keypad (console). Can also be the control board.
The usual way to troubleshoot is to check the keypad with a meter, if OK then it is usually the control board. Unfortunately I cannot find keypad pin-out information. Try the connector cleaning below.
Also try to run the diagnostics on the tech sheet.
Also check that the wires that go from the control to under the unit are OK.
Connector Cleaning
Unplug the unit
Open it up
Clean the edge connector.
