Whirlpool wtw5000dw0 bad vibration
I have a wtw5000dw0 whirlpool wash machine that once it hits the led light for rinse it vibrates crazily.. changed suspension.all looks ok underneath.. went thru errors and at first got pressure switch error but after clearing and trying again no code and and still problem after this bad vibration I stop cycle and put it on drain and spin and that works ok… took off drain pump and it is ok, but still issue like its out of balance just on the rinse LED cycle.. pressure switch is on the board fyi…
Did you replace all 4 of the suspension rods?
yes all 4 changed..pulled motor checked ok. splutch looks ok.. only thing I haven’t done is pull washplate which I cant get off but when put on “drain and spin” cycle it works ok.. got feeling its pressure transducer onboard??
Can you explain vibration a little more in detail. Is the unit spinning, agitating or just LED showing rinse?
