Whirlpool WTW4816FW3 stuck on draining
Brand:Whirlpool
Model Number:WTW4816FW3
Main Symptom:constantly on drain
What happens & when: I unplug it and plug it back in and it starts draining for a few minutes. I try to run a wash cycle and as it starts filling it starts draining and won’t cycle
If you remove the back console panel and disconnect the pressure hose from the main control, does the drain pump continue to run? If it does, the main control has failed. W11603810 Electronic Control Board (Control Module) | Genuine Whirlpool OEM In Stock
