Rachem
1
Whirlpool WRX735SDHZ07 makes but does not dispense Ice
Brand: Whirlpool
**Model Number :**WRX735SDHZ07
Main Symptom: Makes but does not dispense Ice
What happens & when: Always
Parts or tests already tried: Replaced relay switch
Photos/video link: None
If the auger motor is not running then check to make sure that the motor is getting 120 vac. If it is then this will be a faulty auger motor.
Rachem
3
Thank you so much, for your quick response.
The auger is turning. Which makes me believe that the “corkscrew” is also turning but the ice does not come out of the chute.
