Brand: Whirlpool
Model Number: WRS325SDHZ08
Main Symptom: The icemaker isn’t working.
I was able to reset it a few weeks ago & it worked but has stopped again. Reset does not work. Does the icemaker assembly need to be replaced or is there another fix?
If the icemaker will not cycle in the service diagnostics then this will most likely be a faulty icemaker.
(Whirlpool W11700250 Icemaker (AP7219248) - AppliancePartsPros.com)
Thats what I thought. Thank you!
The icemaker was overflowing, on the café bottom freezer refrigerator. I replaced the icemaker and it is still overflowing. Is this something you could help me with? Do I need a new water valve I don’t see any adjustments on the icemaker.
