Brand:Whirlpool
Model Number:WRS321SDHZ01
Main Symptom:Large Temperature Fluctuations
What happens & when: Intermittant
Problems started with fridge warm, freezer cold. Did some basic troubleshooting, unplugged for a bit and it was OK for a while once I plugged it back in. Then it got stupid again and now on both sides. So I called a tech. At that point the coils in the freezer were frozen up, which I hadn’t noticed. He did his thing and said it was either the defrost heater or the main PC board. Told me I should be able to defrost it, get all the water out and at least get through the holidays because it would take at least two weeks to ice over again.
So we did that. Removed the inside freezer panel, waited, and verified no ice. Plugged her back in and it ran great for an hour or so. Fridge side went from 68 to low 50’s fast and then stalled for a couple of hours. Then eventually got into the 30’s.
However, according to my temp monitors it will still jump up to the mid to high 40’s at times and send me an alarm, which won’t trigger unless it’s above 45 for at least 15 mins.
Since we started seeing problems right away, long before it had time to ice over and impede air flow, I’m leaning towards ordering a board. But I’d appreciated any other troubleshooting recommendations. Obviously, I’d hate to buy the board and be stuck with it if that won’t solve the issue. Presently it’s 32 and 0.7, which would be fine, but last night for no reason, it got to 47 on the fridge side.
