Whirlpool WRQA59CNKZ Damper testing
Brand:
Model Number:
Main Symptom:How to test damper to make sure its not the problem.
What happens & when:5 year old unit, freezer is right on at 0 degrees. Reefer on top consistently 6 degrees above set point of 36 degrees. Don’t want to replace the damper if I can’t confirm that is the problem. I would think these devices are more robust than 5 years.
Parts or tests already tried: Disassembled fridge liner to get at damper behind the airtower. Damper was 60% closed with power off. Re-assembled thinking of what next step would be, as I plugged in the wire to the damper, it moved. Need specific test to confirm unit is faulty.
This model has a service pointer about the temperature issues.
service-pointer-w11512008-reva.pdf (175.0 KB)
