Brand:whirlpool
Model Number:Wed757sdhz04
Main Symptom:not making ice
What happens & when:The red light for bin sensor was not on and bin was empty. I replaced emitter board and receiver board. The unit still didn’t make ice! I then checked codes and it gave me a f5 code! The ice maker worked for almost a year and then stopped again! The e5 code is showing again..
Error Code (if any):e5
The error E5 indicates either the ice maker thermistor or the main control have failed. Usually, this is going to be an issue with the ice maker itself rather than the main control. However, this can be verified by placing a thermometer into the ice maker section and closing the door. From there, unplug the power cord and access the main control. At connection P7, test from the pink wire at pin 1 to the tan wire at pin 2. There should be a high resistance reading somewhere close to 23,000 Ohms. If the thermistor fails, replace the ice maker. If it measures close to what it should, the main control has failed.
Ice maker- W11658802 Ice Maker | Genuine Whirlpool OEM In Stock
Main control- W11224256 Electronic Control Board | Genuine Whirlpool OEM In Stock
