My Whirlpool Washer stated intermitently skipping the fill cycle and moving directly to the agitate/wash cycle. I believe the rinse cycle is avoided as well. Started noticing the problem a couple of weeks ago, and it first seemed to be remedied by switching the water level knob from “small” to “medium,” then the agitator would stop and the tub began to fill. Sometimes the problem would not be present at all and the machine would work properly. Now the problem has worsened to the point where at any wash setting the machine will not fill but jumps to the agitate/wash cycle.
The hoses are not kinked or clogged, neither are the screens. Since it will at times fill with water after messing w/ the H20 level knob, I believe the water inlet valve is working properly. Is it the H20 level switch that is bad, or is the timer not sending power to the H20 inlet valve to open to allow the machine to fill?
