My Whirlpool Washing Machine Does Not Spin Down Clothes. What Parts Are Causing This To Happen ?
Hi.
Does the washer spins at all? Does it drains?
Thank you.
Simon.
[quote=Simon / APP Team;760085]Hi.
Thank you.
Simon.[/quote]
THE WASHING MACHINE TUB APPEARED TO WANT TO SPIN, BUT DOES NOT SEEM TO SPIN NOW.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Thank you.
Simon.[/quote]
THE MACHINE DOES DRAIN.
Hi.
If the washer agitates remove the agitator and check if the drive block is not stripped AP6008836
If the drive block is OK then most likely the problem is the clutch AP3094537
Here are the breakdown diagrams and Replacement parts for Whirlpool GSW9650LW0 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
