Whirlpool washing machine making loud noise
Brand: Whirlpool
Model Number: WTW4900BW0
Main Symptom: loud noise during spin cycle
Loud noise in spin is probably worn suspension rods or bad hub, rods if it’s banging and shaking,hub if the basket feels loose or slipping.
IS the noise a loud banging, a grinding, or is it a different noise? If it sounds like a jet engine taking off, or something similar to what a roller coaster sounds like, the issue would be with the bearings in the gearcase. Grinding can be the clutch assembly or the shift actuator. While banging noises can be caused by a loose/damaged hub, a counterbalance ring issue, or a suspension rod failure.
Gearcase- W11454372 Washer Transmission Gear Case | Genuine Whirlpool OEM In Stock
clutch assembly- W10721967 Washer Drive Clutch Kit | Genuine Whirlpool OEM In Stock
Shift actuator- WPW10006355 Washer Shift Actuator | Genuine Whirlpool OEM In Stock
Suspension Rods- W10780044 Washer Suspension Rod Kit | Genuine Whirlpool OEM In Stock
Hub- W10528947 Drive Hub Kit | Genuine Whirlpool OEM In Stock
Counterbalance ring and spin basket assembly- W10521298 Washer Inner Basket Assembly | Genuine Whirlpool OEM In Stock
