Whirlpool washer
while in wash and rinse cycle machine makes a loud noise, sounds like raking gravel.
Sounds like the problem is a bad bearing. The fix is to replace the outer tub assembly.
Hi Gene, Thanks for reply. Does the tub only spin in wash and rinse cycle? Can only the bearing be replaced? How difficult is it to replace the outer tub? Should these washers without a agetator make more noise than usual?
Bob
This bearing is a part of the outer tub and can not be replaced separately. The outer tub does not spin. The transmission shaft goes through the central seal/bearing. This job requires complete disassemble of the washer.
[quote=Gene;677747]Sounds like the problem is a bad bearing. The fix is to replace the outer tub assembly.
Gene.[/quote]
Gene,
Seems like problem is in gear box.
How does wash plate come off?
Remove the cap and the screw (#1 & #2 on the diagram).
I found the instructions for you. They are attached to the reply.
Removing the top.pdf (208.7 KB)
Removing the tub ring.pdf (111.5 KB)
Removing the impeller and basket.pdf (112.7 KB)
Removing the gearcase.pdf (97.2 KB)
[quote=Gene;683246]I found the instructions for you. They are attached to the reply.
Gene.[/quote]
Gene,
I figured that out. Purchased outer tub assembly to fix bad bearing as advised. I do not see any bearing, just seal like on old one. Should there be some type of bearing?
Gene,
Any reply to no bearing in outer tub?
[quote=Gene;679236]This bearing is a part of the outer tub and can not be replaced separately. The outer tub does not spin. The transmission shaft goes through the central seal/bearing. This job requires complete disassemble of the washer.
Gene.[/quote]
They make bearing replacement kits, and I have replaced several bearings already. I am a Sears Repair Tech, and am unsure if the kit is available online… it should be. I can look in my van and include the part number. Although I would not recommend this task for anyone that lacks experience with taking things apart.
[quote=jd1md1;684098]Gene,
I figured that out. Purchased outer tub assembly to fix bad bearing as advised. I do not see any bearing, just seal like on old one. Should there be some type of bearing?[/quote]
You cannot see the bearing as it is beneath the seal…
I found the bearing kit… it includes the tools in the kit. Of course this is for the Elite and/or Cabrio.
Part # W10435302
Instructions
http://media.fotki.com/1_p,skdtbtsdgkfbddfxgtqsskgwtqkq,vi/wgqbrtkbkxttbsqqbbtxttdgbrfdq/1/1303472/5961857/image4917797453812306690img-or.jpg
http://media.fotki.com/1_p,skdtbttddtbdsgqxgtqsskgwtqkq,vi/ttdgbrfdqxrgdbtrwkgxsswtggwqw/1/1303472/5961857/image1750482247419457303img-or.jpg
Sorry, my bad. I mixed this newer model with traditional Cabrio washer. If you ordered the outer tub from APP then you can return it for full refund.
There are 3 parts which could cause such noise. They are: the pulley, the cam and the basket drive gear (#13, #12 & #10 on the diagram). You have to remove them and check the teeth and splines.
Post the results.
jd1md1,
I have reviewed your order. The tub we sent in replacement of the first one is in route now. If you or someone is home to accept the package from Fed-Ex it can be refused and sent back to the warehouse. If you are unable to refuse the package we can also have a pick up tag sent out to you.
For assistance please call our toll free number at 1-877-477-7278 and let them know of the situation. I will put notes in your order.
Our apologies for the inconvenience.
Thank you for choosing AppliancePartsPros.com
Thanks Gene, I though I was nuts looking for bearing. After completely tearing down and not finding bearing I removed belt shield,belt was off of cam and cut thru shield, this is what was making noise until belt came off cam, then would not complete cycles. Another weird one to add to your bag of tricks.
Bob
Thanks Markham, I have found my washer does not have a bearing.
You are welcome Bob. Thank you for the feedback and good luck with your washer.
