The washer timer that I recenty bought from you is either defective or requires a different installation method.
Timer part numbers:
Washer manual part number - 3358741
Label on old timer - 3358741A
Label on new timer - 3946439B
Part number found when searched on your web site -
[LEFT][COLOR=#000000]Part Number: AP3605418
Manufacturer’s Number: 285938 (3358741)
Made by Whirlpool
[/COLOR]
[COLOR=#000000]The timer that was removed has 2 threaded holes for installation with 2 crews. The new timer that I bought from you does not have threaded holes and therefore cannot be installed using the screws.[/COLOR]
[COLOR=#000000]Is the timer I bought defective? Should it have threaded holes?[/COLOR]
[COLOR=#000000]If not, what is the correct installation method for the new timer?[/COLOR]
[COLOR=#000000] [/COLOR]
[COLOR=#000000]Thanks[/COLOR]
[COLOR=#000000]Kurt[/COLOR]
[COLOR=#000000] [/COLOR][/LEFT]
