The washer was trying to agitate and spin, but was not appearing to do so. It would run through a cycle, fill and drain, but the clothing was still wet. After numerous attempts at finding the problem I finally pitched it over and looked underneath. What I found was apparently (from the technician’s manual Whirlpool so wonderfully hid between the frame and basket) the run capacitor which had melted down.
I ordered a new part part with matching part number and just installed this evening. Hooked everything back up and lastly plugged in washer. A hum shortly started after being plugged in. I can’t tell if it is from the capacitor or the motor. It is strong enough to vibrate the floor a tad. Can anyone tell me what the real problem here may be?
I have a picture of the melted part if it would help, but can’t seem to find a way to post it.
Thank you!
