The lid switch on this washer keeps coming loose and we have to slam the lid to trip the switch to make the machine work. Where are all of the screws to tighten or how do I fix this problem?![]()
On these I’ve seen the screws that hold the lid to the hinge come loose and cause this problem. They are on the side of the lid. If that’s not it, it could be the switch itself. It has a sort of clip built into it so that it just snaps into place. Sometimes you can heat this “clip” a little bit with a lighter, and bend it “out”, so that it holds in place.The lid has to be open to take out the switch, or to put it back in. You may have to just replace the switch.
