Whirlpool washer getting grease on clothes
The grease seems to be coming from the agitator - at the top (where the fabric softener cup would go - i don’t use this, so don’t keep it on). ANy ideas how to fix this? Can i fix myself or is it better to call someone…?
THANKS
Its most likely not GREASE, I would suspect undesolved soap, Fill the washer with HOT water, add 1 cup of calgon water softner and 1 cup of clear household amonia, (no clothing) let it go through a COMPLETE CYCLE, Repeat again, this will take care of your problem!!! The reason I say its not oil or grease is because oil can not run 15" UP-HILL, The transmission is way in the bottom of the machine, and its the ONLY part with oil or grease in it!!! Good Luck!!!:slight_smile:
Since oil is lighter than water, wouldn’t any leaking oil product float to the top and deposit on the clothes and agitator top? Anyway, I am currently trying your suggestion with CLR and ammonia since I couldn’t find Calgon. After that I’ll try several washloads and watch for stains.
