Whirlpool Washer fills with water then stops
At start of cycle tub fills with water then stops. I manually move the dial but nothing happens.
I have verified that lid close mechinism is okay and I replaced the pump.
Looking to see if I can test timer or whatever else could be the problem.
Thanks in advance.
wilbobluk
Why did you replace the pump? Wondering if you replaced the pump trying to repair the current problem or if this problem started after you replaced the pump.
If you have tried the timer in all the cycles, I would suspect that it is the culprit. Just curious, though: What prompted you to replace the pump?
Replaced pump as part of this problem. Just did it today - no change
I removed the pump to see if anything was obvious.
When I put it back it had a smalll leak so I replaced it.
