Whirlpool Washer drum locked! HELP
Please help! I have changed the coupling, drive block and clutch! Machine fills, agitates (agitator works fine) and drains, but the drum/tub never moves! So the water drains out but no spin. I do hear the motor humming. How do I fix it? Any suggestions are appreciated! Thanks, Hexster
You have jammed brake shoes, or something stuck between the spin basket and tub. If you turn the tranny coupler clockwise and it is very hard to turn when the clutch engages spin, that confirms it.
having similar problem on whirlpool. how to do get/see between spin basket and outer tub??
thanks
To see into the tub, you use a strong light in the basket.
Okay, so if I find something there, how does it come apart, so I can take it out?
thank you!
Go to my sticky above,“replacing direct drive washer brake shoes” for info on this.
