Brand: whirlpool
Model Number: wtw4800bq1
Main Symptom: drive block fit
I just completed a transmission replacement, and now trying to finished reassembly. I purchased a replacement drive block, tub nut, and agitator to go with fresh transmission.
All of the guides I can find show drive blocks requiring some force to install or uninstall. My replacement can easily be put on/off transmission shaft with little to no friction.
Visually it’s the same size and dimensions as oem, and had the same part number.
After tightening the tub nut, I can lift the entire tub + tub nut + and drive block of transmission shafr easily in one combined piece. I presumed the tub nut would have prevented me from doing this.
Could the drive block I ordered be out of spec vs OEM if I can take it off/on so easily? I have the impression it should be press fit tight.
I am concerned continuing to install new agitator and starting a spin cycle could damage the new transmission or damage splines on new agitator base.
