Whirlpool W2RXEMMWB01 replacement ice maker leaking
Brand: Whirlpool
Model Number: W2RXEMMWB01
Main Symptom: Ice maker leaking
What happens & when: Replacement ice maker leaking every cycle
Error Code (if any): n/a
Parts or tests already tried: ice maker level
Upon water filling the ice cube tray, water leaks out of the rear of the icemaker into the freezer & cube bucket. Fridge is level & so is the ice maker. I have turned the fill timer screw 1/2 turn clockwise to reduce the timer and it still overflows. Order # 17013780
That is either a bad icemaker out-of-the-box or the water valve WP2315576. If adjusting the fill level didn’t seem to change the fill at all I would replace the valve.
WP2315576 Water Inlet Valve | Genuine Whirlpool OEM In Stock
Hi Rory, Appreciate the information & feedback. Thank you. The Water Inlet Valve is new too ( it was replaced a few days before the ice maker was ). What is the process to return/exchange the ice maker itself? Thanks, Jim
You will need to contact customer service at 1-877-477-7278.
